Home » Audio » Group Build » questions re 300b group build
Re: questions re 300b group build [message #32202 is a reply to message #32194] Thu, 22 May 2008 04:16 Go to previous message
RC Daniel is currently offline  RC Daniel
Hmmm, looking at your post, I am gussing you are referring to driving the 300B/s with a pentode *strapped as a triode* - the 1700Hy (grid)choke and Damir's previous threads seem to suggest. If that is indeed the case, disregard the pentode-related suggested below.
Yep, Lundahl can supply 'grid' chokes, as can Magnequest, SAC Thailand (SILK brand), and many other transformer suppliers.
As for driving 300Bs in parallel - quite a task; without doing the calcs, I think it would be pretty borderline... I think you would have some high-frequency roll-off at the operating points suggested, tho don't take my work for it. You could run a parallel driver stage, tho there are probably solutions that are easier to implement and less costly. I wonder what an E180F would sound like with a little more current (and lower plate resistance) - would stand a better chance of driving the parallel output...
Hope this helps in some small way.
Previous Topic: Spare me some IXP10M45S ?
Next Topic: 300B SE Project, Part 9 - E180F, E280F, D3a pentodes - triode connected
Current Time: Sun Oct 25 20:00:30 CDT 2026
