Home » Audio » Group Build » If your thinking about an aluminum top plate and using a nibbler.....
Re: If your thinking about an aluminum top plate and using a nibbler..... [message #32048 is a reply to message #32046] Tue, 03 October 2006 08:20 Go to previous messageGo to previous message
cfranz is currently offline  cfranz
I love those things. Switch, fuse, IEC connector. Not particularly expensive, but a pain to cut.
I've not tried this... yet... I'm going to give it a shot with a router and a metal sidecutter bit. Aluminum isn't a particularly hard metal, it should work even with a wood bit (although you'll probably have to replace the bit more often).
if it works, I'm going to create a template for use with a 3/8 collar.
Previous Topic: The "Evil" Dr. Brown
Next Topic: 300B SE Project, Part 8 - Common cathode 6SN7 triode driver
Current Time: Tue Oct 20 16:58:51 CDT 2026
