Home » Audio » Group Build » SE 300B Project, Part 13 - The finished amp
Re: Wow! :-) [message #31935 is a reply to message #31934] Sat, 22 July 2006 04:56 Go to previous messageGo to previous message
horny is currently offline  horny
hi Damir
I build the whole set by myself
the speakers are 60cm Oris horns with AER md3 drivers.
The woofers are 15 inch bd15 in a b.r cabinet in front hornloaded with 80 cm Oris horns.
The woofers are active with a plxxo this is a line level filter direct behind the head amp.
So the caractre of the amp is given to the bass unit.
As bass amp i use a diy gainclone with very good power supply big trannie and 14 Black gates in super e cap config.
My diy dac is one tda 1543 nonoversampling type.
the turntable is also diy and weigts 38 kg.
(i have a picture if you like)
i do it with a link:
http://forum.audiofreaks.nl/index.php?topic=6571.0
scroll down and you see it
you cant see the motor on the pictures its a separate engine behind the turntable driven with a very thin wire
Stepup trannies are from Tribute Audio
and the phono amp is diy.
The passive pre amp are 2 (left and right separate)
autoformers from Tribute Audio.
Cables are all diy.
The sound of the speakers can i explane as it are magnifying glasses
the amp that drives them must be very good.
Every thing that is not right is direct audible.
if you feed them crap you get very much shit
If you give them a little hum you get enormouse hum in the room
It must be under the 1 mv and this is still a little audible.
but with the right aplifier they can sound like heaven
very very detailed with enormouse dynamics and pressure
also with 1,5 watt.
I have also an diy 300b amp
but i like the sound of a 45 more.
But thats just my taste
Previous Topic: Any new project ideas for winter?
Next Topic: Spare me some IXP10M45S ?
Current Time: Thu Nov 19 05:52:11 CST 2026
