Home » Audio » Group Build » SE 300B Project, Part 13 - The finished amp
| Re: SE 300B Project, Part 13 - The finished amp [message #31926 is a reply to message #31925] |
Tue, 11 July 2006 11:33   |
Damir
Messages: 1005 Registered: May 2009
Illuminati (2nd Degree) |
Unfortunately, I don`t have any experience with TVC - please, try it and report how it worked out!  For the input capacitance of CCS loaded (I assume that you use CCS?!) stage, we must "count" on large "Miller" capacitance. Although EC8010 data said Cag=1,9pF, Morgan Jones measured 4,6pF-4,8pF (!), and if it is actually true, you can expect ~ 300pF on the triode input! If you have "Valve Amplifiers 3" - it`s on the page 560 and around...  For C3g, data said Cag in triode 2,7pF, let`s say 3pF - then we can expect probably ~160pF of input capacitance. Again, my opinion is to build the 90% of the amp "as is" (PS and output stage, and part of the input stage), then temporarily try EC8010 on its socket and its parts soldered on socket pins. Then try C3g version, with various options (Rk or LED bias, g3 connections...). Only then you`ll know for sure what works for you.
By: Damir on Mon, 26 June 2006 12:25
By: Damir on Mon, 03 July 2006 06:08
By: horny on Sun, 09 July 2006 13:26
By: Damir on Mon, 10 July 2006 07:08
By: horny on Tue, 11 July 2006 09:23
By: Damir on Tue, 11 July 2006 10:08
By: horny on Tue, 11 July 2006 10:37
By: Damir on Tue, 11 July 2006 11:33
By: horny on Fri, 21 July 2006 04:19
By: Damir on Fri, 21 July 2006 07:46
By: horny on Fri, 21 July 2006 08:38
Wow! :-)
By: Damir on Fri, 21 July 2006 14:06
Re: Wow! :-)
By: horny on Sat, 22 July 2006 04:56
Re: Wow! :-)
By: Damir on Sun, 23 July 2006 07:14
Re: Wow! :-)
By: horny on Sat, 29 July 2006 03:59
By: horny on Sun, 13 August 2006 04:04
By: Damir on Sun, 13 August 2006 16:00
By: horny on Wed, 16 August 2006 14:43
By: Damir on Thu, 17 August 2006 07:45
By: red on Wed, 01 August 2007 06:24
Current Time: Thu Nov 19 05:52:06 CST 2026
