Home » Audio » Group Build » SE 300B Project, Part 13 - The finished amp
| Re: SE 300B Project, Part 13 - The finished amp [message #31924 is a reply to message #31923] |
Tue, 11 July 2006 10:08   |
Damir
Messages: 1005 Registered: May 2009
Illuminati (2nd Degree) |
Hey, I tried various resistors "across" the grid choke, from 100k-1Meg. It can help a little to damp RCL resonance, and/or to "kill" RF oscillations problems... Sometimes I thought that I hear not much of the difference, but in the end my conclusion was that it somehow "kills" that 3D "sound" and sounds somehow "flatter" and 2D...huh, too much "audiophile" language...  But, I noticed that the grid choke can be a giant pick-up on the input grid, oscillations and unstable work/sound are possible... You must mount it very close to the 300B socket, at least 1-2cm from the chasis, it`s orientation in respect with other magnetic components (OPT) is important... and check for oscillations. Lower values of parallel resistor "defeat" any benefit of the grid choke, IMO ... your 10k in parallel with high impedance of the choke is 10k...but also in the parallel with unecessary choke winding capacitance. And not just that - this grid resistor of 10k is actually in parallel with triode`s load (anode resistor, or CCS when you use anode out), and this resultant driver load is too low. In other words, your driver "sees" just the 10k as a load, parallel with Cw... not too good, IMO. Large input capacitance of EC8010 means that you must be carefull not to use large series resistance (pot) before the tube - HF "roll-off".
By: Damir on Mon, 26 June 2006 12:25
By: Damir on Mon, 03 July 2006 06:08
By: horny on Sun, 09 July 2006 13:26
By: Damir on Mon, 10 July 2006 07:08
By: horny on Tue, 11 July 2006 09:23
By: Damir on Tue, 11 July 2006 10:08
By: horny on Tue, 11 July 2006 10:37
By: Damir on Tue, 11 July 2006 11:33
By: horny on Fri, 21 July 2006 04:19
By: Damir on Fri, 21 July 2006 07:46
By: horny on Fri, 21 July 2006 08:38
Wow! :-)
By: Damir on Fri, 21 July 2006 14:06
Re: Wow! :-)
By: horny on Sat, 22 July 2006 04:56
Re: Wow! :-)
By: Damir on Sun, 23 July 2006 07:14
Re: Wow! :-)
By: horny on Sat, 29 July 2006 03:59
By: horny on Sun, 13 August 2006 04:04
By: Damir on Sun, 13 August 2006 16:00
By: horny on Wed, 16 August 2006 14:43
By: Damir on Thu, 17 August 2006 07:45
By: red on Wed, 01 August 2007 06:24
Current Time: Thu Nov 19 05:52:02 CST 2026
