Home » Audio » Group Build » A few measurements
A few measurements [message #31891] Mon, 29 May 2006 19:40 Go to previous message
For what there worth. I am referring to my somewhat sketchy notes. These were done in haste, I don’t like to run my 300b’s with the filaments sideways. I was mainly just checking that I hadn’t just built an oscillator and was not driving any of my expensive bits to destruction.
2Vp-p input = 200V output into 16 ohms
At @ 225Vp-p I would just start to see a flattening of the negative going wave. I did not stop to check if it was the driver or output stage
I ran a few frequency sweeps, mostly to check for peaks, or oscillation.
If I remember correctly, (Damir, help me out here) -3db is .707 % of the reference (150Vp-p into 16 ohms) value. If so that corresponds to 12Hz to about 42kHz. The .5 power points are < 10Hz to 85kHz.
Square wave response looked pretty good. a good sharp leading edge and almost no overshoot till > 10k or so.
Like I said this is not meant to be a scientific evaluation. I just wanted to know if it was safe to hook up…John
Previous Topic: But I'm still on step 9...
Next Topic: The bass is back.
Current Time: Sun Nov 01 02:59:26 CST 2026
