Home » Audio » Group Build » SE 300B Project, Part 12 - C3g driver
Re: Do you think it is possible... [message #31889 is a reply to message #31888] Tue, 23 May 2006 14:28 Go to previous messageGo to previous message
IMO - no, the voltage "swing" is only +/- 70Vp maximum, B1+ = 400-410V and Ua=190V. Lacking the scope, I can`t see the waveshape at the CCS output, I can only tell what I heard. The sound is very clean and direct - not a sight of distortion.
I think that Pete Millett measured about 0,04% THD with CCS-ed D3a in triode with 10Vrms out...It is about 0,2% with 50Vrms out, pretty good.
The load is high-impedance grid choke.
Again, I don`t have a THD meter...huh. But, Russ - I lose the interest about theoretical speculations a bit - this empiric (trying different things and listening test) phase is even more interesting. I`d also like to know why the tube with lower rp sounds "softer" then similar, higher rp one? Then sound of capacitors and resistors, PS...
Yes, I have various theories...based mostly on theory - but again, without proper measurements I can have just the part of the picture, for now.
Anyway, the amp sounds fine - I think that I`ll use E180F for the driver...huh, I have only two....for now...
Previous Topic: The bass is back.
Next Topic: tried the 6688
Current Time: Sun Nov 01 05:07:26 CST 2026
