Home » Audio » Group Build » Choke cpaazitance, round 2
Choke cpaazitance, round 2 [message #31847] Tue, 28 March 2006 04:41 Go to previous message
Hy-hy!!!,
I did a frequency sweep like I did for the MQ items. These have a large C-core, and dual sectioned coils, one on each leg. The core is gapped with some poly film. L at 6o cps is ~650 Hy. The gap took a bit of L out, but past expeience shows that they sound better if the L is more disconected from signal level.
Anyway...these both resonated at a few cps past 1k Hz. As predicted by theory, the impedance goes through the roof, and the starts falling.
This behaviour leaves me wondering about using Iron like this with high output Z drivers in Zero-nfb amps. Good thing that for open loop amps, one does not usually deal with high source Z on purpose...:)
I am modifying the amp so that the slightly taller chokes can be installed, and then the Brown will hit the fan( no slight to the package mis-handlers at UPS intended ).
cheers,
Douglas
Previous Topic: Measuring Z impedance
Next Topic: AE transformers and chokes for 300B project
Current Time: Sun Nov 01 03:58:28 CST 2026
