Home » Audio » Group Build » CCS Failure Possibilities
Re: whaaaaaat? [message #31799 is a reply to message #31798] Sat, 04 March 2006 07:40 Go to previous message
Hey-Hey!!!,
The battery bias (from output end of R-set to the source) allows a larger R-set value for a given current. The battery voltage plus the bias voltage is used for the V, i is left as the design value, and R is solved for with Lord Ohm's eq'n. One can use up to 4 of the 3,3Volt Li-Ion button cells and not worry about Zener leakage on the G-S clamp.
The batteries are then R-C fileted/decoupled from the gate with a 250k resistor and .015 or bigger capacitor. The Russian teflon is a fine piece in this position, but a small poloystyrene/foil should be quite good as well.
cheers,
Douglas
Previous Topic: 300B SE Project, Part 7 - Common cathode 6C45Pi triode driver
Next Topic: Say Doug; how would you go about..
Current Time: Sat Nov 07 08:40:44 CST 2026
