Home » Audio » Group Build » CCS Failure Possibilities
CCS Failure Possibilities [message #31785] Wed, 01 March 2006 15:46 Go to previous message
Studying Damir's six part design tutorial for an SE amp I thought I noticed that should a CCS Mos-Fet burn out it would put the entire B+ through your expensive 300b or whatever other tube you are designing around; most likely causing a mini bomb in your amp. Damir confirms that this could in fact occur and should be protected against with a resistive fuse placed between the tube and the CCS. He can explain it better but my concern is that the remaining resister could flame on and start a fire in any CCS loaded tube amp.
We need some dialogue regarding this potentially dangerous issue.
I just want to state that this is true for any CCS load; not just Damir's design which is designed safely well within the proper guidelines.
I would not want to think I had to always stay in the room whenever a CCS amp is on in order to keep watch on it.
Previous Topic: 300B SE Project, Part 7 - Common cathode 6C45Pi triode driver
Next Topic: Say Doug; how would you go about..
Current Time: Sat Nov 07 08:11:38 CST 2026
