Home » Audio » Group Build » 300B SE Project, Part 7 - Common cathode 6C45Pi triode driver
Re: 300B SE Project, Part 7 - Common cathode 6C45Pi triode driver [message #31769 is a reply to message #31768] Sun, 26 February 2006 13:14 Go to previous messageGo to previous message
Yes, some can be even "triggered" sometimes by some sounds/frequencies, I`m pretty sure. But, as I said - without scope we can only guess...
If you have similar symptoms, check all your connections/grounding and rewire it - "stopper" resistors close to the pins (non-inductive, say CC), and very short wires.
Previous Topic: Ping Doug
Next Topic: CCS Failure Possibilities
Current Time: Sat Nov 07 09:25:29 CST 2026
