Home » Audio » Group Build » Bias supply
ooooohhhh! neat [message #31740 is a reply to message #31737] Tue, 31 January 2006 17:13 Go to previous messageGo to previous message
Hey-Hey!!!,
That is about as simple as it is reasonable to do. Single filament TX is easy enough, and I have heard a few amps fairly quiet with that arrangement. The Miller neutralizing caps are quite optional, with no grid choke to contribute additional capacitive loading, the 10k output Z of the pentode stage should drive it well.
With a 12.6-0-12.6 and two diodes full wave and 25V capacitors a small negative supply for the cathode CCS is very easy. Radio Shack has a 450 mA TX for ~$7 and the 25v caps are quite inexpensive. 470R, 1/2 Watt resistors and make a CDC Pi filter.
It's easy to add the small caps later. Get it together, and listen...:) I will soon be unwinding a Peerless S-230-Q to clone for this project. The small 6k6 a-a output is probably the best budget Iron for such a project.
cheers,
Douglas
Previous Topic: In the proper Tube tradition...
Next Topic: inductor winding and bobbins
Current Time: Mon Oct 12 08:17:18 CDT 2026
