Home » Audio » Group Build » Bias supply
yes it does... [message #31736 is a reply to message #31733] Fri, 27 January 2006 13:30 Go to previous messageGo to previous message
The CT inductor the 2A3's grids are attached to is the divice in question. Ground its centre, and drive one end. The signal at the other end is 180-degrees out of phase. It is interleaved to make sure the two are of equal magnitude and phase-opposite. It does work well if driven by a low impedance source.
If I didn't like a straight diff amp, as drawn for Galahad, it is an attractive option. The stage as drawn also has room for improvement( read that: well tweaked complication ). It has to look possible for the lower skill/confidence levels too. ONe can either spend a lot of time with support, or a lot of time simplifying. I think the end result of the former results in better amps...:) The end result of the latter is greater profit, so that's a non-issue in this forum.
cheers,
Douglas
Previous Topic: In the proper Tube tradition...
Next Topic: inductor winding and bobbins
Current Time: Thu Nov 26 07:24:02 CST 2026
