Home » Audio » Group Build » Resistor choices for SV811 project
Re: Resistor choices for SV811 project [message #31570 is a reply to message #31567] Tue, 06 December 2005 15:59 Go to previous messageGo to previous message
Hey-hey!!!,
Look at potential voltages across the resistors. Power dissipated by the resistor is V-squared over R, in watts. There is normal operating voltage, and failure or voltage excursions which increase the dissipation.
The Kiwame CF is a decent resistor, and reasonable as DIY products go.
The main PS capacitors should have small bleeders. The hot cathode of the front stage will do most of it, and the residual will be taken care of by your proposed values.
Have you looked at the data sheet for this valve? At B+ of 500, and grid voltage of 0, this triode is going to pass 150 mA. That's 75W of anode dissipation. Also, cap coupling a Zero bias amp looks a bit questionable to me. Clearly, I have not built this SE amp, or even played with one of these valves, but by the provided schematic, and Svetlana data sheet I have questions.
cheers,
Douglas
Previous Topic: The shunt capacitance of grid and anode chokes
Next Topic: C-Core grid chokes
Current Time: Fri Oct 16 00:43:01 CDT 2026
