Home » Audio » Group Build » New PCB for the CCS
New PCB for the CCS [message #31042] Fri, 15 April 2005 13:52 Go to next message
Hi, nice to be back...
I built two "universal" CCS "module" on the PCB. Marker and nail- polish, then Fe-III-Chlorid, as usual...Thanks Doug for the mosfets:-)
I added local decoupling cap 1uF/630V (not necessary). Dimensions of the board are 32x75mm. As you can see, I didn`t install R3 yet, I planned to use a fixed resistor. I tried both CCS with battery and they worked, but didn`t try it in the real circuit so far...
Re: New PCB for the CCS - 2 [message #31043 is a reply to message #31042] Fri, 15 April 2005 13:54 Go to previous messageGo to next message
Another view:
Welcome back [message #31044 is a reply to message #31043] Sat, 16 April 2005 10:02 Go to previous messageGo to next message
Damir, It's nice to see you're back......Colin
Re: New PCB for the CCS - 2 [message #31045 is a reply to message #31043] Sat, 16 April 2005 10:54 Go to previous messageGo to next message
Welcome back!
I'm eager to start an amp project. I know, I never got started on my preamp. But I did save a pair of 2A3's in the hopes we might do something with them here.
Re: Welcome back [message #31046 is a reply to message #31044] Sat, 16 April 2005 12:07 Go to previous messageGo to next message
Thank you all.
New projects (2A3) - actually, I have SE 300B in my mind first. Probably I`ll write about it gradually - output stage, PS, various drivers, etc. - till the finished amp. I have many "breadboard" experiments in plan, expecting new PT from Netherlands, and I hope that I`ll find time/will to post it continuously... I`ll try my best, but don`t expect too much...
Re: Welcome back [message #31047 is a reply to message #31046] Sat, 16 April 2005 14:18 Go to previous messageGo to next message
Damir, I never had a chance to properly thank you for your help with the preamp. Your hand drawn schematic was what I used to wire it up. I don't think I could have done it otherwise. There were a few glitches along the way, but they were my fault. See link for picture of the top.
I'm curious to see what amp you're working on now. Please keep us posted!!!
Colin
Re: Welcome back [message #31048 is a reply to message #31047] Sun, 17 April 2005 06:47 Go to previous message
Thank God your back. Between you and Doug we can get back to work now. No more dwaddling.
Previous Topic: On the amps...
Next Topic: SE or PP?
Current Time: Sun Oct 04 13:34:03 CDT 2026
