Home » Audio » Group Build » Millett's amp
Millett's amp [message #31020] Sat, 19 March 2005 09:58 Go to next message
Say T; why do you think Pete decided not to use ccs but instead goes with tube regulation? I ask only because you said you worked on the E-Linear thing in tandem. Is the fact that that amp is SE have anything to do with it? Also for the more electronically challenged, how do you do the bias wiring and tie-in the ccs1 to the A- leg?
I am going to point out here that as a begginner the Guinevere wireing job had an intuitive feel that could be expressed directly from the schematic; however this is another animal. I look at this schematic and see nothing but questions and few answers pop out at me. What are the catastrophic failure modes possible here and am I seeing this accurately or is this one of those things that look more difficult than they are?
Also can we get a BOM on this ?
Also; I don't see a committment to any particular tube, has this been left open or is it cemented in yet?
Thanks BTW, J.R.
bit by bit [message #31021 is a reply to message #31020] Sat, 19 March 2005 12:16 Go to previous messageGo to next message
He has a pentode running as a SE voltage amp. The g2+plate current thing was giving the diff amp fits as its cathode is CCS-ed. THe cascode triode takes care of this( as long as teh upper valve stays out of grid current operation). The upper grid is also ref'd to the cathodes, a feat which is harder to do properly with a screen grid.
I came up with the idea on the way back from a lunch outing. We re-arranged a test amp immediately, and were quite taken. I kept my mouth closed about the discovery. ~4 months later Peter posted on AA's Tube/DIY what he had been working on and I went public with the PP version soon after.
The CCS is attached to an earlier stage of the bias voltage filter circuit. It is not too critical since it is such a good CCS/regulator. It should go at least one stage before the bias pots os that they can be quite clean of ripple.
What are the catastrophic failure modes possible here. Over voltage on B+ and failure of the CCS2. I am not sure what would happen, since I have not had one fail yet. This is the most critical and 'close to the limits' set of parts on the amp.
It is really fairly simple. One B+( L-C filter, single recitfier), two coupling caps, the plate laods to the front end goint to their corresponding g2 connection or dedicated tap point.
The filaments each have their own winding, two secondary Hammonds of 185 series are quite good for this app. One filament TX for each amp. ONe 50R hum pot for each of the finals.
Yes we can. I will put one together tonight and set it up for discussion.
If you go with UX5 sockets, there are at least three which will work. two are DH, the 1624 and HY69 and the IDH 807 will all plug in with a filament voltage adjustment. This is how I would suggest proceeding.
regards,
Douglas
Re: bit by bit [message #31022 is a reply to message #31021] Sat, 19 March 2005 12:33 Go to previous messageGo to next message
Thanks Doug; That was an excellent response; clear and thorough. Have you spoken to Heybeor yet regarding the special order?
Which tube did you prefer or is it a case of differing"flavors"?
And what was the final amplifier output in watts again, I don't remmember if you stated it.
Re: bit by bit [message #31023 is a reply to message #31022] Sat, 19 March 2005 13:08 Go to previous message
I would say that the power will be between 8 and 12 W. I wish it were more, but that is about it. I can say comfortably that they are good watts and it won't dissapoint. The 807 option may offer something like 15, but I have not built with that one, so its a guess.
I have not yet contacted Heyboer about the build. I am going to do that Monday after hunting some Nickel lams for the grid chokes. It looks like a pair for me, one for Cheetah, one for you and one for Colin. they may be willing to wind a fifth pair for a spare, or perhaps we can get Wayne to make the leap, and then wind 6 pr. to maintain a single stock pair. I may be able to enlist a few other builders while I am at it. I will know more details on Monday.
regards,
Douglas
Previous Topic: New drawings in Projects directory
Next Topic: Iron counting
Current Time: Thu Nov 19 05:50:57 CST 2026
