Home » Audio » Group Build » the Amp
Re: the Amp [message #30850 is a reply to message #30848] Sat, 05 March 2005 18:40 Go to previous messageGo to previous message
Sounds good to me.
Now I just need a little TLC.
On the filament trans I ran one wire from the secondary to each lug on a strip then connected a diode on each lug to the secondary wires. from there I tookthe opposite end of both diodesd and soldered them to one end of a two ohm resistor. I then took the other end of the resistor and soldered it to the pos. end of the first filter cap, with the other end of the filter cap to ground. I also grounded the CT of the RS trans.secondary.
Then I took one end of the second 2 ohm resistor and tied that to the pos end of the second filter cap and ran the neg end of the cap to ground. I then took the tab with the res/cap pos end and ran a wire to pin 4 of the 5687. I then ran a wire from pin 5 to ground. Is this correct?
Previous Topic: Building something new is not easy thing...
Next Topic: Location of Selector Switch in Preamp
Current Time: Fri Oct 16 04:09:12 CDT 2026
