Home » Audio » Group Build » the Amp
the Amp [message #30848] Sat, 05 March 2005 17:54 Go to next message
hey-Hey!!!,
It seems the amp has been settled upon. It will use the guinevere power Iron comfortably.
PP 1624's. this is a glass enveloped version of the 1619. Front end will be a cascode differential amp. One grid grounded so it will SE:PP phase split. One GZ34 rectifier, two 2.5V/2.5A Hammond filament TX's( or perhaps a 5vCT/2.5v-parallel connection with seperate 2.5v windings( PN TBD ). One L-C filter. The 10 Hy/300 mA Hammond is a likely suspect. Perhaps a custom Heyboer... OPTx will be a 10k a-a with g2 taps at 20 and 30%, perhaps 40% as well for future as yet undetermined application/experimentation.
CCS for the cathode of the input stage would be very similar to the Guinevere plate loads. Additional CCS for Ec2 ref would be LND150N3 based and similar construction.
regards,
Douglas
Re: the Amp [message #30850 is a reply to message #30848] Sat, 05 March 2005 18:40 Go to previous messageGo to next message
Sounds good to me.
Now I just need a little TLC.
On the filament trans I ran one wire from the secondary to each lug on a strip then connected a diode on each lug to the secondary wires. from there I tookthe opposite end of both diodesd and soldered them to one end of a two ohm resistor. I then took the other end of the resistor and soldered it to the pos. end of the first filter cap, with the other end of the filter cap to ground. I also grounded the CT of the RS trans.secondary.
Then I took one end of the second 2 ohm resistor and tied that to the pos end of the second filter cap and ran the neg end of the cap to ground. I then took the tab with the res/cap pos end and ran a wire to pin 4 of the 5687. I then ran a wire from pin 5 to ground. Is this correct?
Re: the Amp [message #30851 is a reply to message #30850] Sat, 05 March 2005 18:54 Go to previous messageGo to next message
Looks good to me. Apply voltage slowly while observing for any unexpected behaviour. Use a variac so that you can apply just a little at first if you are worried.
regards,
Douglas
PCB for CCS [message #30852 is a reply to message #30851] Sat, 05 March 2005 19:50 Go to previous messageGo to next message
What do you think it cost to etch approx. 20 boards? I'd much rather go etch than perf board again.....Colin
Re: PCB for CCS [message #30853 is a reply to message #30852] Sat, 05 March 2005 20:37 Go to previous messageGo to next message
I don't know, never done it. Enough practice with perf board and it isn't too hard to stay ignorant about such things...
regards,
Douglas
Re: the Amp [message #30855 is a reply to message #30848] Sat, 05 March 2005 23:13 Go to previous messageGo to next message
I like this idea. Sounds great!
Re: PCB for CCS [message #30856 is a reply to message #30852] Sat, 05 March 2005 23:15 Go to previous messageGo to next message
I can get boards etched for us. But we probably better get 100 minimum, and maybe more than that. Anything less than 100 is a waste of money because it will cost almost the same as 10.
Re: PCB for CCS [message #30857 is a reply to message #30853] Sun, 06 March 2005 05:46 Go to previous messageGo to next message
First let me say I have a buddy who did PCB's himself all the time for little projects and it did not seem too difficult to me. He used to spit them out quite frequently. I am going to try the RS stuff and see what happens. I have the CCS on perfboard but I am curious.
Thanks for reading my wiring post T; It is just the 12v ct heaters that threw me.
T-220 mounting sockets [message #30859 is a reply to message #30857] Sun, 06 March 2005 06:16 Go to previous messageGo to next message
Found T-220 mounting sockets at Digikey. They are around $1.50 per. Any interest? I know they would sure help me out, since I broke a lead screwing around last night....Colin
Re: T-220 mounting sockets [message #30860 is a reply to message #30859] Sun, 06 March 2005 07:29 Go to previous messageGo to previous message
Minimum order?
Previous Topic: Building something new is not easy thing...
Next Topic: Location of Selector Switch in Preamp
Current Time: Fri Nov 06 08:05:18 CST 2026
