Home » Audio » Group Build » Advice on mounting CCS
Advice on mounting CCS [message #30749] Sun, 27 February 2005 12:43 Go to next message
Guys; what are you all doing with your CCS. Are you shock mounting them to the chassis with bolts and nuts?
Are you tieing the output wire's to the solder tabs then letting them hang?
Are you glueing or taping the little perfboard squares to the underside of the chassis then wireing them into the circuit?
Maybe using very short wires and tieing them to the tube pins like Bottlehead does?
Which method is most appropriate for this application?
Thanks; J.R.
Re: Advice on mounting CCS [message #30750 is a reply to message #30749] Sun, 27 February 2005 14:20 Go to previous messageGo to next message
I like to mount the boards next to the socket with a bit of quick setting epoxy. JB Wled Qwik Set works well. Clean the chassis. Carb cleaner is my fav. Don't breath too much ov it though...
Short, solid core wires can work as a safetey feature in case the glue fails.
regards,
Douglas
Re: Advice on mounting CCS [message #30751 is a reply to message #30749] Sun, 27 February 2005 14:22 Go to previous messageGo to next message
I plan to stick mine down with a little Velcro, so I can lift it out to get to the pot's as needed...John
Re: Advice on mounting CCS [message #30752 is a reply to message #30750] Sun, 27 February 2005 17:41 Go to previous message
Sounds like a plan. Thanks.
Previous Topic: hi Damir and all
Next Topic: Common cathode biasing
Current Time: Fri Nov 06 00:25:38 CST 2026
