Home » Audio » Group Build » oil caps
oil caps [message #30694] Fri, 25 February 2005 18:16 Go to next message
The filter cap is not an electrolytic so why are some of the posters assigning polarity to it? Very confusing.
Re: oil caps [message #30695 is a reply to message #30694] Fri, 25 February 2005 18:25 Go to previous messageGo to next message
I'm assuming that the cap side that hooks to the choke is (+) simply because this is B+. This cap terminal is at a higher potentional than the CT terminal, which is hooked to the other side of the oiler, so it would be considered (-).....Colin
Re: oil caps Your correct [message #30700 is a reply to message #30695] Fri, 25 February 2005 18:46 Go to previous messageGo to next message
It's just how you look at it, which ever side you hook to ground becoms Neg. With an oil cap it don't matter which...John
Re: oil caps Your correct [message #30703 is a reply to message #30700] Fri, 25 February 2005 18:57 Go to previous messageGo to next message
cheetah is currently offline  cheetah
It was just easier to type that way. Have been around electronics ling enough to know that very few caps putside the lytic's are polarized.
Joe
Re: oil caps Your correct [message #30704 is a reply to message #30703] Fri, 25 February 2005 19:11 Go to previous message
Thanks guys; appreciate the help and feedback.
Previous Topic: Makin' progress
Next Topic: Rs Filament supply
Current Time: Thu Nov 12 05:02:25 CST 2026
