Home » Audio » Group Build » Going to build Gunevere with you guys...
changes [message #30645 is a reply to message #30643] Tue, 22 February 2005 19:56 Go to previous messageGo to previous message
Well, after I got the little DH amp up and running, I did some surgery. I had been experimenting with pentode front ends. same general format, ground one grid, apply signal to the other and put a good CCS under the cathodes.
So I took out the A441( had been runnig it Quad II style with cathode NFB with its Tertiary winding ) and put in the A431( the Mk.III OPTx ). I needed the screen taps for the E-Linear connection for the front end. 12BY7A's with a shunt regulator for its screens. It Rocks. Almost 40 watts. It makes a lot of heat though.
The Dynaco OPTx is what is holding it back. I need better Iron. Not that it's bad, just the rest is that good.
regards,
Douglas
Previous Topic: supplier dealings
Next Topic: Tertiary winding OPTx windings
Current Time: Thu Nov 05 13:00:26 CST 2026
