Home » Audio » Group Build » By Sunday night...
Re: Yeap, a week from Sunday [message #30585 is a reply to message #30582] Fri, 18 February 2005 15:31 Go to previous messageGo to previous message
hey-Hey!!!,
I'm just chompin' at the bit( well, *YOUR* bit actually ).
This is a new experience for me as well. I suppose I should give you less choices *OR* more clearly defined reasons/options. In the past when I have responded to a "how shall I build a linestage?" there has been a bit more noise in the background and even more options.
On caps, I think I got them from RS as well. If you're careful with making sure there is a load, you can get away with 25 volt rated caps. Root2 times 12.6 is less than 25 and an L-C filter with 25 v-in also yields less than 25 volts.
I've worked with two other folks who built regulated PS versions of this line-amp and it took months longer than this. forgive me for getting excited on your behalf.
regards,
Douglas
ask more questions like open ended 'Why?', you'll not upset me.
Previous Topic: two tubes instead of one
Next Topic: supplier dealings
Current Time: Thu Nov 05 14:05:38 CST 2026
