Home » Audio » Group Build » PCB for the CCS
PCB for the CCS [message #30541] Tue, 15 February 2005 07:04 Go to next message
Here`s the PCB "proposal", I hope that it`ll works without (capacitive/oscillations) problems. I didn`t try it, so far :-).
See that "stopper" resistors R2 & R4 must be mounted with it`s "body" close to the G-pin, "upward". Fix the heatsink somehow (little screws left and right through the board, or...?).
Without "proper", photo process it can be made with nail-polish, then Fe-III-chlorid. Be carefull, good luck!
Brilliant! [message #30543 is a reply to message #30541] Tue, 15 February 2005 07:36 Go to previous messageGo to next message
Looks excellent. Looks like it will be an easy 'Stuff' too.
regards,
Douglas
Re: PCB for the CCS [message #30544 is a reply to message #30541] Tue, 15 February 2005 10:15 Go to previous messageGo to next message
Niice! What about these guys who do one-off prototype boards? Anyone familiar with that?
Re: PCB for the CCS [message #30546 is a reply to message #30544] Tue, 15 February 2005 12:12 Go to previous messageGo to next message
Who needs them?:-) Large part of this hobby is pleasure when you build something all by yourself - allright, "home made" PCB probably won`t looks too proffesional, but so what?
You can buy PCBs in electronic store, adjust dimensions of the little board and traces to your components (little planning in 1:1 on the paper), clean the Cu, then with alcohol-marker draw the traces, and paint them with your favorite nail-polish (avoid glittering one, just ordinary :-)). Buy Fe-III-Chlorid christals (el. store, too), put them in the PVC glass of water, put the board in and wait. "Mix up" a little, it can last a few hours - but then the unprotected Cu "go away", clean the lacquer with polish remover (acetone). Use ~0,9mm bore, few holes and that`s it. Use rubber gloves. Check the traces before and after soldering on little particles and dirt between the traces. Good luck!
Thanks , Doug ! :-) [message #30547 is a reply to message #30543] Tue, 15 February 2005 12:17 Go to previous messageGo to next message
And "5687 anode out" can be easy on the lower part of the PCB if it`s better (in some concrete case), etc.
the 12B4 option... [message #30548 is a reply to message #30547] Tue, 15 February 2005 13:10 Go to previous messageGo to next message
If you don't need as much gain as the 5687 delivers( u=~16 ), the 12B4 is my next option. It takes a second 9-pin socket, and ought to have 6 or 7, instead of 2 LED's to bias. That's about *IT*.
The heaters will take ~25% more curent, at 0.6 amp instead of 0.45 amp of the 5687. Both will run at 12.6 V.
I offer this as an alternative to the gymnastics a lot of ForePlay owners go through getting a reasonable amount of volume knob sensitivity. We're not stuck with 12AU7's so there is no need to act like it at the design table.
Putting in a second socket later oughtn't to be too difficult. Take out the valves before drilling more holes. Reserve a bit of real estate with a Sharpie....
regards,
Douglas
Re: the 12B4 option... [message #30549 is a reply to message #30548] Tue, 15 February 2005 13:30 Go to previous messageGo to next message
Yes, I agree - "modern" sources like CD or DVD are often "hot" and A~16 can be too much... However, I`m sure that those good people here will definitely come to hate you after this...:-) The only chance you can redeem yourself is to make Hg-rectifier (866?) PS (say of "Guinevere" PT- 2x400V), we need exactly B+=304V, haha (9V drop through OPT with Rw=150 Ohms, Uak=250V, Ugk=45V). Current draw - 60mA for the output tube, 8-15 mA for the driver....
Oh...yes! [message #30550 is a reply to message #30549] Tue, 15 February 2005 14:10 Go to previous messageGo to next message
I have only one defense: everybody( with a power TX ), is still working on layout. The option was more of a suggestion to consider chassis design with furhter experiemntation ( of unknown details ).
Don't shoot me please!
Actually, I'd live to have everybody out for a long weekend where we actually put Guinevere together and test for smoke leaks and listen. Lowe's has SS hardware, and there is always Radio Shack in 3 different locations in case we need something that wasn't brought.
regards,
Douglas
Re: Oh...yes! [message #30551 is a reply to message #30550] Tue, 15 February 2005 14:28 Go to previous messageGo to next message
What time are we expected? Budwieser work for you?
Re: Oh...yes! [message #30552 is a reply to message #30551] Tue, 15 February 2005 14:35 Go to previous messageGo to previous message
Well, anytime after 1100 this Saturday would be fine. No beer for me. Diet Dr.Pepper would be fine.
regards,
Douglas
Previous Topic: transformer
Next Topic: Capacitors
Current Time: Sat Jun 15 20:14:51 CDT 2024
