Home » Audio » Group Build » Capacitors
Re: Capacitors [message #30531 is a reply to message #30529] Mon, 14 February 2005 17:44 Go to previous messageGo to previous message
Damir's photo was invaluable in putting together the CCS. Keep it handy.
PC board is not the correct term. I used the plastic breadboards, the ones with lots of holes. You can get them at Rat Shack for a couple of bucks.
I got the LED from Parts Express. Rated at 1.7V and 20mA.
The L-beam has the 5687 heater parts and the CCS bread board.
RCA ins and outs will be mounted on the top plate ala Forepaly.
I'm having a bitch of a time placing all three caps under the hood. I wanted to mount the PS cap through a hole and out the top, but I decided against it. I think this is something I'm going to regreat later on.
My hook-up and bus wires were sent to day, so I should be up and running by the weekend (now there's some famous last words!)
What do you think of the new Tx? Now you can imagine my surprise when I picked my box up expecting only one to be in there. The spare Heyboer is sitting here. I'll hang on to it for as long as you like - no rush AT ALL........Colin
Previous Topic: PCB for the CCS
Next Topic: Silver Lining
Current Time: Sun Oct 25 14:06:07 CDT 2026
