Home » Audio » Group Build » Guinevere layout tips?
Re: Guinevere layout tip, Cap mounting [message #30489 is a reply to message #30487] Sat, 12 February 2005 12:05 Go to previous messageGo to previous message
A good way to mount that big honking 100mf oil cap.
Cut a hole in your top plate that the body will pass thru but not the lip, clean well. slide your cap in from the bottom and run a bead of GE silicone RTV around the lip. Smaller caps and parts, just glue to the chassie. I don't mean bathtub calk, this is the stuff they use to glue aquarium's together befor filling with hunderds of gallons of water.
This stuff is great. It rivels epoxy in it's bond yet is flexable enough that parts don't crack off from vibration or flexing. It is resistant to the heat found around tubes. is a very good insinulater and if you change your mind you can rescue your part with a sharp knife...John
Previous Topic: Ground scheme
Next Topic: Guinevere Schematic links
Current Time: Sat Nov 14 05:25:03 CST 2026
