Home » Audio » Group Build » Att: Damir.
Att: Damir. [message #30386] Fri, 04 February 2005 10:48 Go to previous message
Hi D; On Janurary the 21st. you posted a really nice simple hand drawn schematic of the power supply for Gueinevere. It was easy to follow and complete. Is there any chance I could prevail upon you to do the same for the amplifier section?
I realise it is a lot to ask and I would understand totally if you are not able to do so. I just observed after perusing all of the back posts that your handrawn was the most easily accesible of all the schematics.
Thanks and Thanks for all your help; J.R.
(If you replay that post you will see what I mean, you labeled all the pin-outs for both rec tubes and that was very helpfull.)
Previous Topic: Stoetkit arrived!
Next Topic: Cheap source for R3?
Current Time: Thu Nov 12 06:01:15 CST 2026
