Home » Audio » Group Build » T, confirm correct transformer spec from Heyboer
T, confirm correct transformer spec from Heyboer [message #30264] Mon, 24 January 2005 08:55 Go to next message
I will send an emil to Heyboer regarding our group order so we can get the "bulk" discount. I belive we have 5 orders now. I will ask either for a unique part number or reference number so there is NO confusion in the ordering process.
Are the following specifications correct?
- 100 mA capacity from the HV (400-325-250-0-250-325-400 mulit-tap)
- 3A each of 5V and 6.3V, one 5V and one 6.3V
- both of the heater windigs CT
.....Colin
Re: T, confirm correct transformer spec from Heyboer [message #30265 is a reply to message #30264] Mon, 24 January 2005 10:10 Go to previous messageGo to next message
Also; the 250v windings on the HV side are the rec tube. The 325 is the plate for the 5687, the 400 is what I forgot.
a few things... [message #30270 is a reply to message #30265] Mon, 24 January 2005 15:27 Go to previous message
First, Colin got the spec's right.
The multiple taps are *ALL* rectifier connections. They allow for a PS making ~190V, ~250V and ~320V. The other taps are for maximum rectifier flexibility. Use 5 or 6.3 V rectifiers( and there are a lot of choices ).
We're using the 250-0-250 for the first iteration.
regards,
Douglas
Previous Topic: OT: how are youse for snow?
Next Topic: C1, 4.7uF cap
Current Time: Sun Nov 29 09:28:08 CST 2026
