Home » Audio » Group Build » Motor run cap
Re: Motor run cap [message #30180 is a reply to message #30176] Fri, 21 January 2005 06:43 Go to previous messageGo to previous message
That's teh one. A few things about that cap. My friend bought a whole case of those things. they are about 1% tolerance on the capacitance. They also sound good. A search of similar stuff will probably yeild similar stuff at slightly lower price.
At the quoted shipping, I would call and ask if another means can be arranged less expensively. I suspect they will work with you. But it is my first choice, and I found no close seconds reliably. There are things like used GE 97F series which show up used for less, this is a good second choice. Either way, the 2 1/2 hole is required to surface mount them and it does not matter what you decide to put in the hole at a later date.
regards,
Douglas
Previous Topic: trans order courtesy call
Next Topic: PS schematic
Current Time: Thu Nov 26 04:50:48 CST 2026
