Home » Audio » Group Build » 5687/2a3
Re: 5687/2a3 [message #30027 is a reply to message #30026] Fri, 24 December 2004 07:17 Go to previous messageGo to previous message
Hey-Hey!!!,
There is a fairly easy way for a group to get good Iron. Copy it. All it takes is one sacrificial Iron. I did just this for my HY96 amp. Took a Peerless 20-20 Series and had it unwound by a practiced craftsman. Slighlty modified copies wound on a CNC machine for ~$110 each. This was a 40 Watt/10k a-a, S-265. I wish I had a 20-20 Plus to take apart, but that's for a later project.
With a group, where a half dozen pairs will be wound the additional cost of an original( of what ever OPT is selected ) is not too bad. Some of the likely suspects would be the Acro TO-300, a 6k6 20W item, any of the 20W/5k Peerless 20-20 designs or OEM variants
For a PP 2A3 amp, operating at a SE-specified point( 2k5-5k SE load), anywhere between 5 and 10k a-a ought to work. The SE load mentioned in RCA data sheets is 2k5, and I would suggest a 5k or 6k6 for the project. Take a look at the E-Linear schematic I stuck somewhere( Tubes maybe?), and figure putting the 'screen taps' at 10% or so for just little bit of NFB. If we use a 5687/6H6-Pi or the like, it won't be much.
As to naming it( when it is finally done...) let's leave Merlin for a really advanced revision or another circuit. To mate with the Guinevere linestage, I would be suggesting Arthur of course.
regards,
Douglas
Previous Topic: DC Filament methods
Next Topic: Another idea :-)
Current Time: Thu Nov 19 06:03:14 CST 2026
