Home » Audio » Craftsmen » T-nuts, their care and feeding
Re: T-nuts, their care and feeding [message #29871 is a reply to message #29870] Sat, 27 January 2007 07:16 Go to previous messageGo to previous message
I don't think I understood exactly how you were using the t-nuts (hurricane nuts).Are you putting one t-nut on the back of the furring strip AND one t-nut on the back of the panel? If so -- no, no no! Just one t-nut per mounting hole, on the back of the furring strip. Assuming a 1/4" bolt, you drill a 1/4" clearance hole through the panel and a 5/16" hole through the furring strip. Drop the bolt thought the panel and thread it into the single t-nut. The panel will tighten down nicely.
Bob
Previous Topic: Need to find a cabinet refinisher
Next Topic: Nostalgic DIYers
Current Time: Mon Nov 30 12:33:04 CST 2026
