Home » Audio » Craftsmen » Guess I'll have to build another base for the amp
Guess I'll have to build another base for the amp [message #29827] Wed, 08 November 2006 19:40 Go to next message
Muse took this one over:
Re: Guess I'll have to build another base for the amp [message #29828 is a reply to message #29827] Thu, 09 November 2006 09:40 Go to previous messageGo to next message
Re: Didn't like the way it turned out. It's hers. [message #29830 is a reply to message #29828] Mon, 13 November 2006 16:02 Go to previous messageGo to next message
Working on another with padauk this time. Wait 'til you see what amber shellac does for the color!
Re: Didn't like the way it turned out. It's hers. [message #29831 is a reply to message #29830] Mon, 13 November 2006 21:57 Go to previous messageGo to next message
I'll bet it will look sweet!
Re: Didn't like the way it turned out. It's hers. [message #29832 is a reply to message #29830] Tue, 14 November 2006 16:58 Go to previous messageGo to next message
Really? Well, not into dumpster diving, but if you're gonna toss it... I will say, I really like the bit of lower trim you put on. Get that locally?
Re: Didn't like the way it turned out. It's hers. [message #29833 is a reply to message #29832] Tue, 14 November 2006 18:50 Go to previous messageGo to next message
Made it with a round over bit.
Trade ya for the V-caps?
Re: Didn't like the way it turned out. It's hers. [message #29834 is a reply to message #29833] Wed, 15 November 2006 11:58 Go to previous message
Not likely...
Previous Topic: Filler for mitered edges that aren't flush?
Next Topic: Clear coat tip
Current Time: Sun Nov 08 17:25:39 CST 2026
