Home » Audio » Craftsmen » Finishing Cherry is a pain
Finishing Cherry is a pain [message #29824] Fri, 27 October 2006 17:20 Go to previous message
Using the best advice I can find I've tried just about everything for the '45' amp base and still can't get the look I want.
I've used dye stain then shellac, oil/varnish then shellac, just oil/varnish, just shellac - garnet and amber, shellac then oil; you name it.
Nothing seems to make the grain "pop" and most cloud it. I've got one more idea: a really light coat of oil/varnish followed by amber shellac. Coincidentally, the same finish was featured on a piece in the latest Fine Woodworking. It won't give the dark antique look I originally wanted but should reveal the character of the wood. I hope.
Previous Topic: Edgebanding plywood
Next Topic: finish for waterfall bubinga
Current Time: Tue Sep 22 20:34:22 CDT 2026
