Home » Audio » Craftsmen » Hand drill has a stuck chuck
Re: Hand drill has a stuck chuck [message #29822 is a reply to message #29818] Sun, 22 October 2006 14:01 Go to previous messageGo to previous message
lon is currently offline  lon
I'm back here to give the answer to the stuck chuck on
a craftsman drill problem.
I went to the store.
They guy had the chuck removed in a bout 2 minutes.
Thew trick was not in using the chuck key.
What he did was use the short end of a large diameter
allen wrench in the mouth of the chuck and tighten it down.
Then a tap with a hammer got it loose.
No vise needed, no sweat. Maybe this is in the
instruction manual with new drills. I didn't have
the book.
Previous Topic: Interconnects
Next Topic: Newbee Tools
Current Time: Fri Nov 06 23:13:37 CST 2026
