Home » Audio » Craftsmen » Hand drill has a stuck chuck
Hand drill has a stuck chuck [message #29806] Sun, 15 October 2006 12:05 Go to previous message
lon is currently offline  lon
Years a go I got a used Craftsman reversible power drill.
The chuck 'teeth' are worn down from using it as a hole saw
and I normally remove the chuck to put a drill guide on it.
These days I can't get the chuck out to repair or replace
the head.
The usual tapping of the chuck key on the opposite side
with a mallet doesn't work anymore. It's stuck.
My directions for the drill guide say that the owners manual
for a reversible drill has the answer to this, but I have
none.
Any clues on this besides the chuck key tapping trick?
Perhaps I had the forward/reverse switch set incorrectly.
In any case I can't fix it without maybe going to Sears.
Previous Topic: Interconnects
Next Topic: Newbee Tools
Current Time: Fri Nov 06 22:45:46 CST 2026
