Home » Audio » Craftsmen » Tuba18 Sub
Re: Not so fast there, excursion breath... [message #29638 is a reply to message #29637] Sat, 17 September 2005 11:12 Go to previous messageGo to previous message
Show me another 3.3 cu ft sub that will do 90dB/watt at 30Hz and, more important if you're going to use it to listen to music, 100dB/watt at 40Hz. Then tell me what it costs. If it's less than $100 I'll buy one. BTW, the T18 does what it does using a $35 driver with these measured specs:
fs 30Hz
Qes .26
Qms 12.0
Qts .26
Vas 0.7 cu ft
SPL 85.9
xMax 16mm
Sd 220 sq in
Previous Topic: Solid State vs Vacuum Tube Finish
Next Topic: sub folded horn
Current Time: Mon Nov 09 18:17:48 CST 2026
