Home » Audio » Craftsmen » Tuba18 Sub
Re: Not so fast there, excursion breath... [message #29637 is a reply to message #29636] Sat, 17 September 2005 10:07 Go to previous messageGo to previous message
No one questions that the little horn is operating as a horn from 50Hz up, provided it is used with boundary reinforcement. What is at issue is whether or not the three cubic feet is best used for horn path, or whether it would be better used to gain extension by providing box volume to create an alignment better suited for the bottom octave. If you want response from 50Hz to 200Hz, that's one thing but if you want 20Hz to 100Hz, that's another. By omitting the horn and using all space for the box, you are able to gain more power down low where it is needed for a sub.
Previous Topic: Solid State vs Vacuum Tube Finish
Next Topic: sub folded horn
Current Time: Mon Nov 09 18:17:51 CST 2026
