Home » Audio » Craftsmen » Tuba18 Sub
Re: Just because I'm in the mood to argue ... [message #29627 is a reply to message #29624] Thu, 15 September 2005 14:40 Go to previous messageGo to previous message
That's the point. A 50Hz horn is going to produce the most output above 50Hz. No harm in that. If it is small, then corner loading will improve response ripples. But at subwoofer frequencies, it's going to act as a direct radiator. So it would probably be better to use a driver with specs that lended itself for subwoofer use, i.e. more surface area, lower resonance and greater excursion.
Previous Topic: Solid State vs Vacuum Tube Finish
Next Topic: sub folded horn
Current Time: Mon Nov 09 18:15:28 CST 2026
