Home » Audio » Craftsmen » Solid State vs Vacuum Tube Finish
Re: layering poly [message #29597 is a reply to message #29595] Sat, 10 September 2005 19:11 Go to previous messageGo to previous message
Ive been finishing my archery equipment with poly for a long time (brush on, spray, and wipe on). I apply 3-4 coats of gloss, then 2 coats of semi-gloss, then a couple coats of satin. If it still has a sheen some 0000 steel wool real light will remove it nicely. With this kind of layering you get the protection and hardness of gloss without the shine. Be careful you don't get the types mixed around or it'll eggshell badly. One way to smooth out brush on nicely is to brush it on, let it set for a few minutes, then lightly spray with the same type. This levels it out much better than just brushing.
Previous Topic: PI four enclosure
Next Topic: Tuba18 Sub
Current Time: Mon Nov 09 18:22:24 CST 2026
