Home » Audio » Craftsmen » 2 pi tower baffles
Re: Cats are EVIL! [message #29576 is a reply to message #29575] Sat, 06 August 2005 02:25 Go to previous messageGo to previous message
Lotsa posts on the subject here and Pi. Bob Brines also has good tips. To screw or not to screw. If you use white glue and take your time you can clamp w/o screws. Either way make certain the edges stand proud of the panels a hair. Easy to sand an edge. PITA to sand a whole panel down.
Goe to the Joes site and use his hot iron glue. Other Bill tried it and likes it.
Previous Topic: Matching Colour with Wood
Next Topic: First try at paper-backed veneer
Current Time: Thu Nov 26 11:24:28 CST 2026
