Home » Audio » Craftsmen » Using Hole Saw w/o Center Bit
Re: Yes that's my Bugle knob [message #29421 is a reply to message #29420] Tue, 15 March 2005 11:53 Go to previous messageGo to previous message
Spin the wood on a drill and shape with a belt sander! Bill, you are a crazy man.
I think I'm going to try the hole saw with the center bit to start the cut and then complete it without. I'll need the centre hole for the pot and switch attachement.
Previous Topic: I made the mistake of hooking this up
Next Topic: Need Options for Router Table
Current Time: Sat Nov 07 03:35:05 CST 2026
