Home » Audio » Craftsmen » Plywood Edge Protection
Re: Plywood Edge Protection [message #29391 is a reply to message #29388] Thu, 03 February 2005 17:13 Go to previous message
Not to worry, Ski. The Baltic Birch has such tightly glued plies that you should get decades w/o wear. Many of the speakers of the 50's and 60's were made this way. I would "break" (round-over) slightly the outside edges with some 220 grit garnet paper on a wooden sanding block. Also round over the top corners of the side pieces as they have done in the foto. Transforming all the 90 degree sharp angles into gentle curves will help a lot as will the finsh you apply. Everybody knows how I feel about goopethane but in this case it will offer some additional protection against abrasion so I would use it. Get the Minwax Wipe-On Satin Polyurethane. Looks good.......
for goop.
Merry Pranks Website
Previous Topic: Holes in metal w/o chassis punch. HELP!!!
Next Topic: New Project
Current Time: Mon Nov 23 01:25:48 CST 2026
