Home » Audio » Craftsmen » Need Options for Router Table
Re: I would just add: [message #29369 is a reply to message #29367] Thu, 13 January 2005 03:29 Go to previous messageGo to previous message
When you need a short piece of trim push a longer piece thru the bit and then remove it from the table once you get to the length you need. Your hands never go past the bit.
Drill an 1/8" hole in the table near the bit, place a piece of rod in it and now you have an "index pin" you use to guide the workpiece into the bit for those times when you can't use a fence.
Previous Topic: Using Hole Saw w/o Center Bit
Next Topic: Hard looking joinery made easy
Current Time: Thu Nov 12 02:57:30 CST 2026
