Home » Audio » Craftsmen » Vibration from enclosure surface
Re: Vibration from enclosure surface [message #29305 is a reply to message #29303] Tue, 23 November 2004 11:43 Go to previous message
If a panel resonates at a particular frequency, it will be louder at that frequency. But even if it doesn't, it will still pass sound through it a little bit because sound passes through solids.
If what you're hearing is muted uniformly except for more deep bass, then your cabinet is probably pretty solid. If it is louder at some midbass frequency, then you may have a panel that could use another brace.
Previous Topic: Check this one out!
Next Topic: Craftsmen table saw 10'' model #11327610
Current Time: Sat Nov 07 02:46:20 CST 2026
