Home » Audio » Craftsmen » Need advice on etching, primer, and finish coat to aluminum chassis?
Need advice on etching, primer, and finish coat to aluminum chassis? [message #29258] Thu, 23 September 2004 08:42 Go to next message
Hi everyone,
I would like to paint my Hammond aluminum chassis with a tough splatter type finish.
But since it has been several years, I thought that it would be a good idea if I requested some advice on products and method.
Since I will only be finishing a couple of boxes, I hope that what ever products that are suggested, will be available in an aerosol spray can?
Any method of finishing and product information will be greatly appreciated?
Thanks
Norris Wilson
Re: Need advice on etching, primer, and finish coat to aluminum chassis? [message #29259 is a reply to message #29258] Thu, 23 September 2004 17:36 Go to previous message
See the post from Auntie-Polly on Tubes Forum here. The red looks even better in person. Rustoleum Professional. Limited colrs but great stuff. Clean the aluminum with Formula 401 or other grease cutter. Wipe off carefully. Primer. Paint.
Previous Topic: No table saw? No problem - build a sawboard
Next Topic: Welcome!
Current Time: Fri Aug 16 03:20:39 CDT 2024
