Home » Audio » Craftsmen » No table saw? No problem - build a sawboard
Re: No table saw? No problem - build a sawboard [message #29257 is a reply to message #29252] Thu, 23 September 2004 07:28 Go to previous message
I took a week off last month for a furniture building course and was amazing at how simple some of the "tricks" were. I was most impressed by examples of "woodworking math", where complex geometry problems were solved without any calculations at all. I came out of that course realizing that woodworking isn't so much skill-based, but rather knowledge-based.
Another idea that really sunk in was that you don't build things to fit against a ruler, but rather against each other. Don't waste time measuring something with a ruler or a mic if you can use that piece directly as a guide. This sawboard is a perfect example of that.
gar.
Previous Topic: Back to square one, so to speak
Next Topic: Need advice on etching, primer, and finish coat to aluminum chassis?
Current Time: Fri Nov 27 06:28:44 CST 2026
