Home » Audio » Craftsmen » Back to square one, so to speak
Re: Back to square one, so to speak [message #29246 is a reply to message #29241] Wed, 01 September 2004 08:23 Go to previous messageGo to previous message
Jeff Robinson is currently offline  Jeff Robinson
I hope it's better than it's predecessor (model 7242). I bought one and consider it a toy grade machine. The motor burned out after cutting about 20 3.5" holes (I set the spindle speed to the correct RPM for each hole saw size I used). I now have a much better unit from Ryobi, #WDP1850. It's also rated at 1/3 Hp but the motor is about 4 times the size of the (alleged) 1/3 Hp Chinese motor on the Central Machinery (Harbor Freight) unit.
good luck
Jeff
Previous Topic: Other plywood tricks
Next Topic: No table saw? No problem - build a sawboard
Current Time: Fri Nov 27 06:43:28 CST 2026
