Home » Audio » Craftsmen » Other plywood tricks
Re: The veddy British 'Housing Joint' [message #29221 is a reply to message #29219] Wed, 18 August 2004 20:35 Go to previous messageGo to previous message
The Auntie-Polly is currently offline  The Auntie-Polly
Lon, grab a piece of plywood 3/4" thick. Put a 3/8" Dado stack in your table saw and set the fence for a 3/8" cut, 3/8" deep. You'll have to play around a bit because the 3/4" plywood is actually 23/32. What you want to arrive at is a fence and blade depth seting that puts a rabbet on the edge that is exactly 1/2 of the thickness of the plywood in both dimensions.
Run the plywood on edge and cut the rabbett.
Now move the fence back another 1/2 width, approx 3/8" so you cut a groove approx 3/8 from the END of the board you are joining. That's a Dado. 3/8 from the edge, 3/8 wide and 3/8 deep.
The tongue you made on the EDGE of the one panel will fit perfectly into the groove you made on the inside FACE of the other.
That's a housing joint. It's very strong not just from the increased gluing surface but a good mechanical joint too.
The Terry Cain recommended joint is a LOCK MITER and is easy to cut with a set of lock miter cutters and a router table. NBD
Previous Topic: Using a fly cutter
Next Topic: Back to square one, so to speak
Current Time: Sun Nov 15 20:57:29 CST 2026
