Home » Audio » Craftsmen » Quick poll: what would you veneer with out of these?
Re: JARRAH [message #29215 is a reply to message #29213] Wed, 18 August 2004 03:49 Go to previous messageGo to previous message
Nah, been lazy on the finishing but wanna do it now. Its just the finishing I have to do otherwise theyve been done for awhile now.
The pre-veneered MDF here can only be got in either 13mm thick or 19mm thickness. Would you say 13mm MDF is thick enough, or should I go 19mm thick in case mouth resonances are gonna be a problem for this 300hz horn? (29cm long, something like 1088cm^2 mouth area I think).
The horn in the picture uses 16mm plain MDF, cant get the veneered MDF in 16mm though just 13mm and 19mm.
I dont like putting on veneer, just building the horns again from pre-veneered MDF is the easiest for me.
Previous Topic: What's the deal with Baltic Birch plywood?
Next Topic: Using a fly cutter
Current Time: Thu Nov 26 12:07:21 CST 2026
