Home » Audio » Craftsmen » First routing experiences less than rousing
Re:Insert flap "A" and throw...... [message #29187 is a reply to message #29186] Sun, 01 August 2004 16:37 Go to previous messageGo to previous message
....the Roto-zip away. Hopefully you bought it at the Depot as well.In which case you can return it and the accessories and get a 40 or 50 dollar Ryobi plunge router which will do all you need.
If not possible, hold on for dear life and make several passes that are maybe 1/4" of the rabbett at a time. Then make the finish pass and finally, go clockwise, known as a "climb cut" to finish the edges.
The Roto and Dremel tools are for making outlet cuts in drywall and thin sheet metal. Also OK for polishing and small grinding. Everything else is wishful thinking.
Previous Topic: Jasper Jig on Sale at PE
Next Topic: Couple of Poly questions
Current Time: Sat Oct 17 05:12:38 CDT 2026
