Home » Audio » Craftsmen » Here's a crazy question for you...
Here's a crazy question for you... [message #29181] Fri, 30 July 2004 08:01 Go to next message
Anyone ever thought about, or actually tried to veneer the outer surface of a plastic horn flare, to give it that woodhorn look?
Gar.
Re: Still crazy after all these years [message #29183 is a reply to message #29181] Fri, 30 July 2004 17:48 Go to previous messageGo to next message
Go for it. Might have to use contact cement and it cant get any worse that that in itself.
If you scuff the plastic you might get an epoxy to bond. You'll have to experiment with bonding agents. You could try some of that silly peal and stick veneer for fun if that will bond.
Extra flat veneer. Cut the pieces to fit like you would marquetry. The fate of the job will lie with the glue
Re: Still crazy after all these years [message #29184 is a reply to message #29183] Sat, 31 July 2004 16:34 Go to previous message
Believe it or not, I'm taking a marquetry course in a couple of weeks time. Maybe I will give it a shot after that.
Previous Topic: Must Have software for amp building
Next Topic: Jasper Jig on Sale at PE
Current Time: Thu Nov 19 14:24:49 CST 2026
